40-180 push button alignment
Yes that method is a good one and I have used it for years. Most all stations are right on frequency, so you don't have to worry about having a super accurate signal generator using this method, the station does it for you.
Joe
40-180 push button alignment - by mountain man - 03-05-2014, 06:54 PM
RE: 40-180 push button alignment - by Joeztech - 03-23-2014, 04:15 PM
RE: 40-180 push button alignment - by klondike98 - 03-23-2014, 04:53 PM
RE: 40-180 push button alignment - by DeckApe - 03-23-2014, 05:32 PM
There are currently 8768 online users. [Complete List]
» 2 Member(s) | 8766 Guest(s)
