Model 650B Tombstone Project
Good luck with that "puppy" Ron. Hope you can "git 'er dun" the way you want. I've got a 640 that's really a nice set with great sound. This series of sets seem to be great performers, and maybe geared to those radio buyers who couldn't quite afford a 116, or other high-end set.
Ed Martin
Benwood, WV
Model 650B Tombstone Project - by Ron Ramirez - 12-04-2005, 01:27 AM
[No subject] - by don'tdomelikethat - 12-04-2005, 10:11 AM
[No subject] - by Ron Ramirez - 12-04-2005, 05:26 PM
[No subject] - by don'tdomelikethat - 12-04-2005, 05:59 PM
[No subject] - by Ron Ramirez - 12-04-2005, 07:16 PM
[No subject] - by Bill Hutchinson - 12-04-2005, 09:00 PM
[No subject] - by Ron Ramirez - 12-06-2005, 12:04 PM
[No subject] - by Bill Hutchinson - 12-08-2005, 11:43 AM
[No subject] - by Derek D - 12-12-2005, 01:29 PM
[No subject] - by Ron Ramirez - 12-12-2005, 02:28 PM
[No subject] - by Ron Ramirez - 12-19-2005, 01:55 AM
Re: Model 650B Tombstone Project - by Ron Ramirez - 05-23-2011, 07:47 PM
There are currently 10205 online users. [Complete List]
» 1 Member(s) | 10204 Guest(s)
