38-10 Volume
Recapped & replaced out of tolerance resistors
Plays but low volume touch top of tuning cap with insulated screw driver plays loud. Wave same under oscillator tube volume increases.
changed out tubes also with tested new ones. where do I start
I am new to this.[/b]
38-10 Volume - by joeo - 03-24-2014, 02:35 PM
RE: 38-10 Volume - by morzh - 03-24-2014, 04:10 PM
RE: 38-10 Volume - by David - 03-24-2014, 04:22 PM
RE: 38-10 Volume - by joeo - 03-25-2014, 11:19 AM
RE: 38-10 Volume - by Mondial - 03-25-2014, 12:16 PM
RE: 38-10 Volume - by Steve Davis - 03-25-2014, 12:18 PM
RE: 38-10 Volume - by klondike98 - 03-25-2014, 01:33 PM
RE: 38-10 Volume - by morzh - 03-25-2014, 01:35 PM
RE: 38-10 Volume - by David - 03-25-2014, 04:56 PM
RE: 38-10 Volume - by joeo - 03-26-2014, 07:43 AM
There are currently 9841 online users. [Complete List]
» 1 Member(s) | 9840 Guest(s)
