46-1201 CAP QUESTION
All the practice you need to get you started:
Get any generator, hook it up, get it to oscillate, and then start from trying to get a stable picture. Then just rotate your controls and see what they do. Change offset, V/div, trigger level, time base, switch triggering modes. Play with it. It will be like a tutorial.
Following this, observe the safety rules and then you could try to see some real life things in your radio. Remember, do not use millivolts/div when looking at 100s of V/div or you could damage your front end amp.
Regular 1:10 probe with 10M input resistance is good for about 300V or so. So do not measure high DC levels with it.
46-1201 CAP QUESTION - by davidff - 03-13-2014, 09:53 AM
RE: 46-1201 CAP QUESTION - by morzh - 03-13-2014, 10:15 AM
RE: 46-1201 CAP QUESTION - by codefox1 - 03-17-2014, 09:53 AM
RE: 46-1201 CAP QUESTION - by davidff - 03-19-2014, 08:06 AM
RE: 46-1201 CAP QUESTION - by TV MAN - 03-19-2014, 09:44 AM
RE: 46-1201 CAP QUESTION - by davidff - 03-19-2014, 11:22 AM
RE: 46-1201 CAP QUESTION - by morzh - 03-19-2014, 11:36 AM
RE: 46-1201 CAP QUESTION - by davidff - 03-19-2014, 01:06 PM
RE: 46-1201 CAP QUESTION - by morzh - 03-19-2014, 01:25 PM
RE: 46-1201 CAP QUESTION - by davidff - 03-24-2014, 10:26 AM
RE: 46-1201 CAP QUESTION - by Eliot Ness - 03-24-2014, 11:26 AM
RE: 46-1201 CAP QUESTION - by morzh - 03-24-2014, 11:50 AM
RE: 46-1201 CAP QUESTION - by Eliot Ness - 03-24-2014, 01:31 PM
RE: 46-1201 CAP QUESTION - by morzh - 03-24-2014, 02:30 PM
RE: 46-1201 CAP QUESTION - by Warren - 03-24-2014, 03:36 PM
RE: 46-1201 CAP QUESTION - by morzh - 03-24-2014, 04:18 PM
RE: 46-1201 CAP QUESTION - by Warren - 03-24-2014, 07:54 PM
RE: 46-1201 CAP QUESTION - by morzh - 03-24-2014, 08:58 PM
RE: 46-1201 CAP QUESTION - by Warren - 03-24-2014, 11:48 PM
