Starting a Philco 60 chassis restore
About grommets: every time I need one I measure where they go and how high I need them and just go to Lowe's. If I have an old one - even better.
Almost always I could get what I need, even if it is a combo of a grommet and a rubber washer to pad it if the thickness is not enough.
Then of coures there is Mark, there is the Renovated Radios.
Knobs are possibly reproduced, but you could start asking here: at least one person here deals in knobs - Mike Koste and his Gobs of Knobs, again, Mark Oppat, Julie McCall.
Go to Home Page and choose Resources, they are all there.
RE: Starting a Philco 60 chassis restore - by morzh - 03-24-2014, 04:37 PM
