46-1201 CAP QUESTION
Thanks Mike... I have hooked up the signal generator to it and gotton used to the controls etc. I do need to learn how to troubleshoot with it on a radio, etc. My probe has a switch on it to switch to x 10.. or is it x 100 i forget, will have to check. So, if I switch it then I can measure higher than 300 volts.. correct?
46-1201 CAP QUESTION - by davidff - 03-13-2014, 09:53 AM
RE: 46-1201 CAP QUESTION - by morzh - 03-13-2014, 10:15 AM
RE: 46-1201 CAP QUESTION - by codefox1 - 03-17-2014, 09:53 AM
RE: 46-1201 CAP QUESTION - by davidff - 03-19-2014, 08:06 AM
RE: 46-1201 CAP QUESTION - by TV MAN - 03-19-2014, 09:44 AM
RE: 46-1201 CAP QUESTION - by davidff - 03-19-2014, 11:22 AM
RE: 46-1201 CAP QUESTION - by morzh - 03-19-2014, 11:36 AM
RE: 46-1201 CAP QUESTION - by davidff - 03-19-2014, 01:06 PM
RE: 46-1201 CAP QUESTION - by morzh - 03-19-2014, 01:25 PM
RE: 46-1201 CAP QUESTION - by davidff - 03-24-2014, 10:26 AM
RE: 46-1201 CAP QUESTION - by Eliot Ness - 03-24-2014, 11:26 AM
RE: 46-1201 CAP QUESTION - by morzh - 03-24-2014, 11:50 AM
RE: 46-1201 CAP QUESTION - by Eliot Ness - 03-24-2014, 01:31 PM
RE: 46-1201 CAP QUESTION - by morzh - 03-24-2014, 02:30 PM
RE: 46-1201 CAP QUESTION - by Warren - 03-24-2014, 03:36 PM
RE: 46-1201 CAP QUESTION - by morzh - 03-24-2014, 04:18 PM
RE: 46-1201 CAP QUESTION - by Warren - 03-24-2014, 07:54 PM
RE: 46-1201 CAP QUESTION - by morzh - 03-24-2014, 08:58 PM
RE: 46-1201 CAP QUESTION - by Warren - 03-24-2014, 11:48 PM
