City: Sedona, AZ/Placentia/CA
Probably not Mike but the replacement of the large cap can may make it easier for you. It was relatively painless and we all like that. That part was actually fun with no nasty tar to remove. For a modest price I will send you the "magic" bolt, you must supply a very well mounted vice. ![Icon_lolno Icon_lolno](https://philcoradio.com/phorum/images/smilies/icon_lolno.gif)
Best, Jerry
RE: Starting on Philco 111. - by jerryhawthorne - 03-24-2014, 08:23 PM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
