  • 1 Vote(s) - 5 Average
Philco model 70 rebuild - by Tim P.
#75
Well, good, Tim. I never repaired one of those but them being simply a copper leaf and a piece of insulation you could see if you have some insulation problem. I am sure it can be replaced with a piece of mica from a donor cap or in my case there was some material, like mylar or something.
Philco model 70 rebuild - by Tim P. - by TV MAN - 01-29-2014, 11:46 AM
RE: Philco model 70 rebuild - by Tim P. - by morzh - 03-25-2014, 10:16 AM
Users browsing this thread: 19 Guest(s)
