42-323 tennite front grill
Hey everyone, thanks for the advice! I'll try some epoxy to fix the crack. I am fortunate in that my grill still mostly comforms at the edges, and the bowed section in the lower middle part is bowed inward, towards the speaker. It's quite symmetric, almost natural-looking.
42-323 tennite front grill - by mark03 - 03-17-2014, 05:24 PM
RE: 42-323 tennite front grill - by mark03 - 03-20-2014, 07:40 PM
RE: 42-323 tennite front grill - by klondike98 - 03-20-2014, 09:18 PM
RE: 42-323 tennite front grill - by Jamie - 03-23-2014, 10:46 AM
RE: 42-323 tennite front grill - by Ron Ramirez - 03-23-2014, 12:17 PM
RE: 42-323 tennite front grill - by Eliot Ness - 03-23-2014, 01:48 PM
RE: 42-323 tennite front grill - by OldRestorer - 03-24-2014, 07:45 AM
RE: 42-323 tennite front grill - by mark03 - 03-25-2014, 12:30 PM
Philco 91 Tuning Condenser
There are currently 9285 online users. [Complete List]
» 2 Member(s) | 9283 Guest(s)
