Refinishing the chassis compartment
For me,
I like a nice clean inside. I also like it to be original looking so not shellac or shiny finish. I just brush it out, give it a good cleaning or even a #0000 wool rubbing and sometimes stain it. Some cabinets are more unfinished than others with rough cut wood and imperfections so I feel that they will catch and hold more dust and dirt. Those cabinets I will give a sanding.
In the end, it is your cabinet and if you want it looking beautious inside then go for it. It will definitely make it cleaner and easier to keep clean.
Kirk
RE: Refinishing the chassis compartment - by OldRestorer - 03-25-2014, 12:46 PM
RE: Refinishing the chassis compartment - by TimC - 03-25-2014, 08:24 PM
Philco 91 Tuning Condenser
There are currently 9144 online users. [Complete List]
» 2 Member(s) | 9142 Guest(s)
