A Philco Super 71 Slideshow (and a Super 89 slideshow too!)
Ron, that's a beautiful radio! I'm still planing on doing your super oscillator mod on my model 19. It was really rough when I got it, rusty chassis, most of the veneer along with the next layer underneath on the front arch was missing. I have finished restoring the chassis and the cabinet. It looks pretty good considering what I had to start with. It's one of those that if you stand back about ten feet it looks very good. But it will never be a museum piece. So I have no quams about experimenting with it. If it works out, I may try the mod on a 91 I have. But I'm still between houses and without a work bench. I'm thinking by fall things will be gitting back to normal and I will be able to work on some radios.
M R Radios   C M Tubes
[No subject] - by Michael Dennis - 07-21-2008, 11:53 AM
[No subject] - by Steve Davis - 07-21-2008, 07:26 PM
[No subject] - by Ron Ramirez - 07-22-2008, 06:55 PM
[No subject] - by Ron Ramirez - 07-22-2008, 07:31 PM
[No subject] - by Steve Davis - 07-22-2008, 08:13 PM
[No subject] - by etech - 07-22-2008, 09:27 PM
[No subject] - by Steve Davis - 07-22-2008, 10:06 PM
[No subject] - by etech - 07-22-2008, 10:23 PM
[No subject] - by Ron Ramirez - 07-22-2008, 10:31 PM
[No subject] - by etech - 07-22-2008, 10:42 PM
[No subject] - by BDM - 07-22-2008, 11:08 PM
There are currently 8864 online users. [Complete List]
» 5 Member(s) | 8859 Guest(s)
AvatarAvatarAvatarAvatar
