Philco BOL 41-608 Turntable--HELP
Hi Brian,
I restored a 41-608 about a year ago. I don't recall a flex joint to couple the motor to the platter. IIRC, the motor spindle drives two idler wheels that in turn drive the platter. I can look at the service manual on it when I get home.
Sean
WØKPX
Philco BOL 41-608 Turntable--HELP - by Guest - 07-21-2008, 08:44 PM
[No subject] - by Sean - 07-22-2008, 01:37 PM
[No subject] - by Guest - 07-22-2008, 03:50 PM
[No subject] - by Sean - 07-22-2008, 09:58 PM
[No subject] - by Sean - 07-22-2008, 10:15 PM
[No subject] - by Guest - 07-22-2008, 11:57 PM
There are currently 7745 online users. [Complete List]
» 4 Member(s) | 7741 Guest(s)
AvatarAvatarAvatarAvatar
