Tuning indicator tube
http://www.ebay.com/itm/Pair-of-NOS-NIB-...3f32cd0d91
If no one bids, get them.
Meantime, is the a socket that has a resistor inside or something? Have you checked?
Tuning indicator tube - by fields 100 - 03-26-2014, 10:10 AM
RE: Tuning indicator tube - by morzh - 03-26-2014, 10:15 AM
RE: Tuning indicator tube - by fields 100 - 03-26-2014, 10:26 AM
RE: Tuning indicator tube - by morzh - 03-26-2014, 10:58 AM
RE: Tuning indicator tube - by rocketeer - 03-26-2014, 03:33 PM
RE: Tuning indicator tube - by vinzer - 03-26-2014, 04:29 PM
RE: Tuning indicator tube - by fields 100 - 03-26-2014, 04:59 PM
RE: Tuning indicator tube - by jerryhawthorne - 03-26-2014, 09:43 PM
RE: Tuning indicator tube - by fields 100 - 03-26-2014, 10:07 PM
RE: Tuning indicator tube - by jerryhawthorne - 03-26-2014, 11:40 PM
RE: Tuning indicator tube - by fields 100 - 04-05-2014, 04:41 PM
RE: Tuning indicator tube - by codefox1 - 04-05-2014, 05:23 PM
