  • 1 Vote(s) - 3 Average
TESLA 54C Yogoslav
Bradley,
I just got home from work. I shouldn't have gone on line this morning before going to work as I ended up rushing.
Before I forget here is a link to a Czech web site. If it works correctly for you you should see a colum of various Tesla radio model numbers.Clicking on one should give you various pictures some will include the chassis from the bottom. Although your radio is not there there is a lot of information regarding it's Czech cousins.
The link should start you off with a model 405u which I am in process of restoring.It is not my particular radio but the same model number.
http://teslaradio.webgarden.cz/rubriky/r...ndard-405u
There is a bottom chassis view.Also see the manual voltage adjustment switch.
Henry
( radiohenry@aol.com)If you want to e-mail directly.
TESLA 54C Yogoslav - by Bradley Rush - 03-20-2014, 04:52 PM
RE: TESLA 54C Yogoslav - by radiohenry - 03-24-2014, 04:52 PM
RE: TESLA 54C Yogoslav - by radiohenry - 03-24-2014, 05:07 PM
RE: TESLA 54C Yogoslav - by radiohenry - 03-24-2014, 07:19 PM
RE: TESLA 54C Yogoslav - by Arran - 03-24-2014, 10:23 PM
RE: TESLA 54C Yogoslav - by Bradley Rush - 03-25-2014, 03:55 AM
RE: TESLA 54C Yogoslav - by radiohenry - 03-25-2014, 04:47 PM
RE: TESLA 54C Yogoslav - by Bradley Rush - 03-26-2014, 12:44 AM
RE: TESLA 54C Yogoslav - by radiohenry - 03-26-2014, 05:30 AM
RE: TESLA 54C Yogoslav - by radiohenry - 03-26-2014, 05:37 AM
RE: TESLA 54C Yogoslav - by radiohenry - 03-26-2014, 03:44 PM
RE: TESLA 54C Yogoslav - by Bradley Rush - 03-26-2014, 05:51 PM
RE: TESLA 54C Yogoslav - by radiohenry - 03-26-2014, 09:05 PM
There are currently 4532 online users. [Complete List]
» 1 Member(s) | 4531 Guest(s)
