Tuning indicator tube
Done all of the above. I usually change all wiring, remove each pin socket, clean and tighten it. All pins have voltage, albeit 30% higher than normal.
I just found out that original 10watt 1,5K B+ resistor had been replaced with 1.0K resistor, hence the elevated B+ on all tubes, but that should not be detrimental to the glow issue.
Tuning indicator tube - by fields 100 - 03-26-2014, 10:10 AM
RE: Tuning indicator tube - by morzh - 03-26-2014, 10:15 AM
RE: Tuning indicator tube - by fields 100 - 03-26-2014, 10:26 AM
RE: Tuning indicator tube - by morzh - 03-26-2014, 10:58 AM
RE: Tuning indicator tube - by rocketeer - 03-26-2014, 03:33 PM
RE: Tuning indicator tube - by vinzer - 03-26-2014, 04:29 PM
RE: Tuning indicator tube - by fields 100 - 03-26-2014, 04:59 PM
RE: Tuning indicator tube - by jerryhawthorne - 03-26-2014, 09:43 PM
RE: Tuning indicator tube - by fields 100 - 03-26-2014, 10:07 PM
RE: Tuning indicator tube - by jerryhawthorne - 03-26-2014, 11:40 PM
RE: Tuning indicator tube - by fields 100 - 04-05-2014, 04:41 PM
RE: Tuning indicator tube - by codefox1 - 04-05-2014, 05:23 PM
