A Philco Super 71 Slideshow (and a Super 89 slideshow too!)
Very nice job on both chassis, Ron. Also, the Philco 70 cabinet refinishing is beautiful. What is a Super 71? My Philco Radio book only seems to list a model 71B.
Oops! Nevermind. I just read this thread. http://www.philcoradio.com/phorum/showth...p?tid=1035
Now I understand.
Ed
[No subject] - by Michael Dennis - 07-21-2008, 11:53 AM
[No subject] - by Steve Davis - 07-21-2008, 07:26 PM
[No subject] - by Ron Ramirez - 07-22-2008, 06:55 PM
[No subject] - by Ron Ramirez - 07-22-2008, 07:31 PM
[No subject] - by Steve Davis - 07-22-2008, 08:13 PM
[No subject] - by etech - 07-22-2008, 09:27 PM
[No subject] - by Steve Davis - 07-22-2008, 10:06 PM
[No subject] - by etech - 07-22-2008, 10:23 PM
[No subject] - by Ron Ramirez - 07-22-2008, 10:31 PM
[No subject] - by etech - 07-22-2008, 10:42 PM
[No subject] - by BDM - 07-22-2008, 11:08 PM
There are currently 10538 online users. [Complete List]
» 3 Member(s) | 10535 Guest(s)
