Tuning indicator tube
Fields, nice to post a link to the schematic. Every radio with an eye tube I have worked on (not your particular tube) has had a 1meg resistor either in the tube socket (mostly) or external and are a source of problems.
Tuning indicator tube - by fields 100 - 03-26-2014, 10:10 AM
RE: Tuning indicator tube - by morzh - 03-26-2014, 10:15 AM
RE: Tuning indicator tube - by fields 100 - 03-26-2014, 10:26 AM
RE: Tuning indicator tube - by morzh - 03-26-2014, 10:58 AM
RE: Tuning indicator tube - by rocketeer - 03-26-2014, 03:33 PM
RE: Tuning indicator tube - by vinzer - 03-26-2014, 04:29 PM
RE: Tuning indicator tube - by fields 100 - 03-26-2014, 04:59 PM
RE: Tuning indicator tube - by jerryhawthorne - 03-26-2014, 09:43 PM
RE: Tuning indicator tube - by fields 100 - 03-26-2014, 10:07 PM
RE: Tuning indicator tube - by jerryhawthorne - 03-26-2014, 11:40 PM
RE: Tuning indicator tube - by fields 100 - 04-05-2014, 04:41 PM
RE: Tuning indicator tube - by codefox1 - 04-05-2014, 05:23 PM
