Refinishing the chassis compartment
Some cabinets have a dark brown colored sealer or paint applied to the inside, almost always flat. In others it looks like it's brown but transparent, so it may be a shellac or animal hide coating they used.
RE: Refinishing the chassis compartment - by TimC - 03-25-2014, 08:24 PM
RE: Refinishing the chassis compartment - by Arran - 03-26-2014, 11:45 PM
Philco 91 Tuning Condenser
There are currently 9289 online users. [Complete List]
» 1 Member(s) | 9288 Guest(s)
