Hi Todd,
Welcome to the Phorum. I believe you are referring to the Bakelite block. If you go here:http://www.philcoradio.com/tech/blocks.htm This will tell you what you need to know.
Eric
The Villages, FL
41-290 - by Todd Kaser - 03-27-2014, 08:36 AM
RE: 41-290 - by Eric Adams - 03-27-2014, 09:44 AM
RE: 41-290 - by TA Forbes - 03-27-2014, 09:45 AM
RE: 41-290 - by Todd Kaser - 03-27-2014, 09:50 AM
RE: 41-290 - by Eric Adams - 03-27-2014, 10:02 AM
RE: 41-290 - by TA Forbes - 03-27-2014, 10:35 AM
RE: 41-290 - by Todd Kaser - 03-27-2014, 10:47 AM
RE: 41-290 - by Joeztech - 03-28-2014, 07:26 AM
RE: 41-290 - by klondike98 - 03-28-2014, 08:11 AM
RE: 41-290 - by TA Forbes - 03-28-2014, 09:59 AM
RE: 41-290 - by Todd Kaser - 03-28-2014, 10:56 AM
RE: 41-290 - by lenmiller - 03-30-2014, 12:40 PM
RE: 41-290 - by Todd Kaser - 03-31-2014, 07:54 AM
RE: 41-290 - by K7Sparky - 04-03-2014, 05:38 PM
RE: 41-290 - by K7Sparky - 04-03-2014, 05:47 PM
RE: 41-290 - by K7Sparky - 04-03-2014, 09:21 PM
RE: 41-290 - by Raleigh - 04-03-2014, 10:06 PM
RE: 41-290 - by K7Sparky - 04-04-2014, 10:30 AM
There are currently 3859 online users. [Complete List]
» 1 Member(s) | 3858 Guest(s)
