A Philco Super 71 Slideshow (and a Super 89 slideshow too!)
Barry does very nice work. It takes a great amount of skill and patience to achieve that level of finishing.
Ed
[No subject] - by Michael Dennis - 07-21-2008, 11:53 AM
[No subject] - by Steve Davis - 07-21-2008, 07:26 PM
[No subject] - by Ron Ramirez - 07-22-2008, 06:55 PM
[No subject] - by Ron Ramirez - 07-22-2008, 07:31 PM
[No subject] - by Steve Davis - 07-22-2008, 08:13 PM
[No subject] - by etech - 07-22-2008, 09:27 PM
[No subject] - by Steve Davis - 07-22-2008, 10:06 PM
[No subject] - by etech - 07-22-2008, 10:23 PM
[No subject] - by Ron Ramirez - 07-22-2008, 10:31 PM
[No subject] - by etech - 07-22-2008, 10:42 PM
[No subject] - by BDM - 07-22-2008, 11:08 PM
There are currently 10554 online users. [Complete List]
» 4 Member(s) | 10550 Guest(s)
AvatarAvatarAvatarAvatar
