philco bakelite blocks
"Jumping" them is not a good idea. It still leaves the old bad part in the circuit, unless you are cutting all the internal leads to the terminals.
I recommend ALWAYS re-building. I assume you've seen this section on my site regarding the bakelite block rebuilding?
BAKELITE BLOCK RE-BUILDING
Easy Steps to Re-building
philco bakelite blocks - by Chris Drumma - 12-04-2005, 03:40 PM
[No subject] - by Chuck Schwark - 12-04-2005, 03:54 PM
[No subject] - by Chris Drumma - 12-04-2005, 04:24 PM
[No subject] - by Ron Ramirez - 12-04-2005, 05:05 PM
[No subject] - by Poston Drake - 12-07-2005, 01:26 PM
[No subject] - by don'tdomelikethat - 12-07-2005, 07:15 PM
[No subject] - by Guest - 12-08-2005, 10:14 PM
[No subject] - by Ron Ramirez - 12-08-2005, 10:44 PM
[No subject] - by Chuck Schwark - 12-09-2005, 12:32 AM
[No subject] - by Ron Ramirez - 12-09-2005, 01:42 AM
[No subject] - by Poston Drake - 12-09-2005, 11:19 AM
[No subject] - by Ron Ramirez - 12-09-2005, 12:52 PM
There are currently 6765 online users. [Complete List]
» 2 Member(s) | 6763 Guest(s)
