Philco model 610 rebuild - by Tim P.
Threads: 10
City: Columbia, SC
http://www.amazon.com/Brown-Colored-Glue...B00AF0MEAO
Here are some brown glue sticks described as 'plasticy.' All else being equal, would you use wax or hot glue?
RE: Philco model 610 rebuild - by Tim P. - by skyscraper - 03-27-2014, 05:54 PM
Users browsing this thread: 13 Guest(s)
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
There are currently 6450 online users. [Complete List] » 1 Member(s) | 6449 Guest(s)
