IF Alignment on Model 19 - what tool?
Klondike,
Thanks for the links. I did a search before I posted my question, but I didn't notice either of them.
Much appreciated.
Jon
RE: IF Alignment on Model 19 - what tool? - by PAradiogeek - 03-27-2014, 07:45 PM
