Thanks for the replies. I'm going to tackle the radio again this weekend. I'll clean the tubes and sockets first. I do have a tube tester, but it has been a little flakey lately. I'll test the tubes first, then dust off the signal generator.
41-290 - by Todd Kaser - 03-27-2014, 08:36 AM
RE: 41-290 - by Eric Adams - 03-27-2014, 09:44 AM
RE: 41-290 - by TA Forbes - 03-27-2014, 09:45 AM
RE: 41-290 - by Todd Kaser - 03-27-2014, 09:50 AM
RE: 41-290 - by Eric Adams - 03-27-2014, 10:02 AM
RE: 41-290 - by TA Forbes - 03-27-2014, 10:35 AM
RE: 41-290 - by Todd Kaser - 03-27-2014, 10:47 AM
RE: 41-290 - by Joeztech - 03-28-2014, 07:26 AM
RE: 41-290 - by klondike98 - 03-28-2014, 08:11 AM
RE: 41-290 - by TA Forbes - 03-28-2014, 09:59 AM
RE: 41-290 - by Todd Kaser - 03-28-2014, 10:56 AM
RE: 41-290 - by lenmiller - 03-30-2014, 12:40 PM
RE: 41-290 - by Todd Kaser - 03-31-2014, 07:54 AM
RE: 41-290 - by K7Sparky - 04-03-2014, 05:38 PM
RE: 41-290 - by K7Sparky - 04-03-2014, 05:47 PM
RE: 41-290 - by K7Sparky - 04-03-2014, 09:21 PM
RE: 41-290 - by Raleigh - 04-03-2014, 10:06 PM
RE: 41-290 - by K7Sparky - 04-04-2014, 10:30 AM
There are currently 4046 online users. [Complete List]
» 1 Member(s) | 4045 Guest(s)
