Battery for 46-350
Paul,
Thanks to the dimensions you sent, last weekend I made a box the right size, put in some connector pins from a computer power supply, and wired up 6 C-cells and 10 nine volt batteries for the A and B supplies. It needs the printed cardboard for the outside, but it is a working battery. (Just kind of ugly.)
One of these days I'll either find an original I can get the cardboard from or else I'll figure out how to print one for myself.
Thanks again.
John Honeycutt
Battery for 46-350 - by Raleigh - 03-09-2014, 08:03 PM
RE: Battery for 46-350 - by RadioDave - 03-09-2014, 10:36 PM
RE: Battery for 46-350 - by Raleigh - 03-09-2014, 11:07 PM
RE: Battery for 46-350 - by WyTex - 03-11-2014, 07:41 AM
RE: Battery for 46-350 - by Raleigh - 03-16-2014, 03:15 PM
RE: Battery for 46-350 - by WyTex - 03-16-2014, 09:29 PM
RE: Battery for 46-350 - by Raleigh - 03-17-2014, 09:53 PM
RE: Battery for 46-350 - by WyTex - 03-19-2014, 11:49 AM
RE: Battery for 46-350 - by Raleigh - 03-19-2014, 04:04 PM
RE: Battery for 46-350 - by WyTex - 03-26-2014, 11:20 AM
RE: Battery for 46-350 - by Raleigh - 03-28-2014, 08:10 PM
RE: Battery for 46-350 - by Raleigh - 04-13-2014, 09:12 PM
RE: Battery for 46-350 - by Raleigh - 04-13-2014, 10:02 PM
Philco 91 Tuning Condenser
There are currently 9055 online users. [Complete List]
» 1 Member(s) | 9054 Guest(s)
