New to the radio restoration world
Welcome Chuck. Can you give us an indication of experience/knowledge in old electronics and an idea of what test equipment you have? It will give us a basis to start you on your journey when the weather improves. Perhaps someone here will have a copy of the schematic for you. You can't go on a journey without a "road map".
Best, Jerry
RE: New to the radio restoration world - by jerryhawthorne - 03-29-2014, 02:07 PM
RE: New to the radio restoration world - by gregb - 03-29-2014, 04:03 PM
RE: New to the radio restoration world - by Jamie - 03-30-2014, 08:36 AM
There are currently 10106 online users. [Complete List]
» 2 Member(s) | 10104 Guest(s)
