New to the radio restoration world
Glad to help.
I messed up the paste of the second web address. Here's another try.
http://www.philcorepairbench.com
Jon
RE: New to the radio restoration world - by gregb - 03-29-2014, 04:03 PM
RE: New to the radio restoration world - by PAradiogeek - 03-29-2014, 04:50 PM
RE: New to the radio restoration world - by Jamie - 03-30-2014, 08:36 AM
There are currently 9382 online users. [Complete List]
» 5 Member(s) | 9377 Guest(s)
AvatarAvatarAvatarAvatar
