New to the radio restoration world
Welcome to the Phorum. Here's a thread that relatively recent on the topic of books useful for learning about radio electronics. It digresses in to other topics by the second set of pages but perhaps it will help.
RE: New to the radio restoration world - by gregb - 03-29-2014, 04:03 PM
RE: New to the radio restoration world - by klondike98 - 03-29-2014, 08:08 PM
RE: New to the radio restoration world - by Jamie - 03-30-2014, 08:36 AM
There are currently 10548 online users. [Complete List]
» 2 Member(s) | 10546 Guest(s)
