Philco PT-69 (Done), 38-62 (Done) & 41-22CL Resto Chronicles
Johnsons paste wax in the yellow can. there are many others.
RE: Philco PT-49 & Philco 38-62 Resto Chronicles - by OldRestorer - 03-29-2014, 08:10 PM
Philco 91 Tuning Condenser
There are currently 8720 online users. [Complete List]
» 2 Member(s) | 8718 Guest(s)
