New to the radio restoration world
Welcome to the forum! Once you get that set playing, you'll become addicted and you'll be searching for other radios. One thing to always keep in mind - you are working with potentially lethal voltages. Make sure you follow safety guidelines... make sure you are never grounded (don't stand on a concrete floor, etc), keep one hand in your pocket, etc. You should make a dim bulb tester before you begin your work, etc.
Good luck and keep us informed!
RE: New to the radio restoration world - by gregb - 03-29-2014, 04:03 PM
RE: New to the radio restoration world - by Jamie - 03-30-2014, 08:36 AM
There are currently 8956 online users. [Complete List]
» 5 Member(s) | 8951 Guest(s)
AvatarAvatarAvatarAvatar
