philco bakelite blocks
Chris
When I was young and foolish, I removed every bakelite block in a Model 18 and replaced them with terminal strips and new Orange Drops.
Soon after, I learned that the bakelite blocks could be rebuilt - but not usually with Orange Drops. That's when I started using the smaller metalized film capacitors and never looked back.
Chuck is right; they should always be restuffed with new caps.
If I still had that 18 lowboy, I would do it over again, the right way. (I have a small stash of bakelite blocks now for when I have one missing or broken in a set.)
Regarding your second question, 0.15 uF would probably be O.K. but 0.1 uF would be a better (closer) sub.
philco bakelite blocks - by Chris Drumma - 12-04-2005, 03:40 PM
[No subject] - by Chuck Schwark - 12-04-2005, 03:54 PM
[No subject] - by Chris Drumma - 12-04-2005, 04:24 PM
[No subject] - by Ron Ramirez - 12-04-2005, 05:05 PM
[No subject] - by Poston Drake - 12-07-2005, 01:26 PM
[No subject] - by don'tdomelikethat - 12-07-2005, 07:15 PM
[No subject] - by Guest - 12-08-2005, 10:14 PM
[No subject] - by Ron Ramirez - 12-08-2005, 10:44 PM
[No subject] - by Chuck Schwark - 12-09-2005, 12:32 AM
[No subject] - by Ron Ramirez - 12-09-2005, 01:42 AM
[No subject] - by Poston Drake - 12-09-2005, 11:19 AM
[No subject] - by Ron Ramirez - 12-09-2005, 12:52 PM
