Model 38-60 Antenna
Good morning all,
Just received the subject model to restore that is complete except for the antenna. It is merely a piece of very small gauge wire about 6 inches long. Must be a kluge. Does anyone know of the correct configuration or materials or part number of an original antenna? Thanks in advance for any help. Rick
Model 38-60 Antenna - by Guest - 07-24-2008, 07:28 AM
[No subject] - by exray - 07-24-2008, 07:45 AM
[No subject] - by BDM - 07-24-2008, 10:17 AM
Model 38-60 Antenna - by Guest - 07-25-2008, 07:34 AM
There are currently 9758 online users. [Complete List]
» 1 Member(s) | 9757 Guest(s)
