Model 38-60 Antenna
There's not an original antenna per se. It is set up to be used with a random length wire (more than 6 inches!) or one of the outdoor dipoles that Philco had on the market at the time that served most all of their radios.
You'll get excellent performance with a random wire, preferably outdoors, as long and high as possible.
Model 38-60 Antenna - by Guest - 07-24-2008, 07:28 AM
[No subject] - by exray - 07-24-2008, 07:45 AM
[No subject] - by BDM - 07-24-2008, 10:17 AM
Model 38-60 Antenna - by Guest - 07-25-2008, 07:34 AM
There are currently 10436 online users. [Complete List]
» 2 Member(s) | 10434 Guest(s)
