New find RCA 810T
The dial lites look too bright . Did the radio have diffusers with the lamps? Maybe it's me.
Henry
New find RCA 810T - by Ronin61 - 03-26-2014, 02:15 PM
RE: New find RCA 810T - by morzh - 03-26-2014, 02:17 PM
RE: New find RCA 810T - by Jamie - 03-26-2014, 05:28 PM
RE: New find RCA 810T - by radiohenry - 03-26-2014, 05:36 PM
RE: New find RCA 810T - by TA Forbes - 03-26-2014, 10:04 PM
RE: New find RCA 810T - by Ronin61 - 03-27-2014, 11:38 AM
RE: New find RCA 810T - by TA Forbes - 03-28-2014, 10:02 AM
RE: New find RCA 810T - by Ronin61 - 03-29-2014, 01:39 AM
RE: New find RCA 810T - by radiohenry - 03-30-2014, 07:38 PM
RE: New find RCA 810T - by Ronin61 - 03-30-2014, 08:27 PM
RE: New find RCA 810T - by Ronin61 - 03-30-2014, 08:29 PM
RE: New find RCA 810T - by Arran - 03-31-2014, 01:17 AM
RE: New find RCA 810T - by codefox1 - 04-04-2014, 03:22 PM
RE: New find RCA 810T - by PhilcoJohn - 04-09-2014, 06:38 AM
RE: New find RCA 810T - by PhilcoMike - 04-09-2014, 02:49 PM
RE: New find RCA 810T - by TA Forbes - 04-10-2014, 01:07 PM
