12" Philco field coil speakers
I have been using 2 Philco 12" field coil speakers in a stereo sound system.
They both have 1000 ohm field coils or thereabouts.
I built a power supply to run them at 95 volts dc.
Am I in the right vicinity with the voltage?
These are really excellent speakers and I am running them fullrange.
Thanks for any suggestions.
Bill Larson
12" Philco field coil speakers - by Guest - 07-24-2008, 09:08 AM
[No subject] - by Raleigh - 08-19-2008, 12:10 PM
There are currently 8189 online users. [Complete List]
» 1 Member(s) | 8188 Guest(s)
