42-380 + ?? escutcheon panel
The one with Bass, Volume, Bands, Tuning sounds like a 41-280.
Maybe somebody just needed to replace the brass strip for some reason and the one from the previous year was handy.
If the knob labeled "Band" feels like a rotary switch, but the chassis is labeled 42-380, then something intriguing is going on.
Edited to add: Are your escutcheons otherwise identical? The 41 and 42 escutcheons are slightly different, I think. The 41 escutcheon is completely flat, but the 42 model is raised a bit around the push buttons to allow the station identifiers to be inserted from the front.
John Honeycutt
42-380 + ?? escutcheon panel - by irawex - 03-30-2014, 05:24 PM
RE: 42-380 + ?? escutcheon panel - by Raleigh - 03-30-2014, 11:01 PM
RE: 42-380 + ?? escutcheon panel - by irawex - 03-31-2014, 09:23 AM
Philco 91 Tuning Condenser
There are currently 8904 online users. [Complete List]
» 2 Member(s) | 8902 Guest(s)
