My vote for the worst chassis to work on (so far)
I avoid the rubber wiring sets if at all possible. With that said, the Philco's I choose to own are 35 through 38 model sets. The sets with sub chassis get my hair up! Hard for me to move my big fat fingers through and around those Icon_confused There are worse sets, but I just won't take ownership of one 8)
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
[No subject] - by Ron Ramirez - 01-03-2008, 06:39 PM
[No subject] - by TonyJSenior - 01-03-2008, 07:30 PM
[No subject] - by BOBC - 01-04-2008, 01:58 AM
[No subject] - by Raleigh - 01-05-2008, 06:22 PM
[No subject] - by Texasrocker - 01-12-2008, 02:00 AM
[No subject] - by Bill Hutchinson - 01-30-2008, 06:58 PM
[No subject] - by Terry Judkins - 01-30-2008, 08:01 PM
[No subject] - by DeckApe - 07-23-2008, 01:19 PM
[No subject] - by Michael Dennis - 07-24-2008, 12:03 AM
[No subject] - by BDM - 07-24-2008, 10:14 AM
There are currently 10482 online users. [Complete List]
» 2 Member(s) | 10480 Guest(s)
