Philco model 208 (code 122)
Hi folks,
My 1st post here... I have been working on a very nice Philco 5-tube table top radio model 208, code 122. It's a Canadian model dating from the mid-to late 50s.
Reference: http://www.radiomuseum.org/r/philco_cdn_...e_122.html
It's that exact same radio except the case is dark burgundy and the speaker transformer is much smaller. It is in very good condition, all original parts and the case is nearly flawless.
I have been looking for a schematic for that model. I could manage without it, but i'd feel more comfortable having the schematic to navigate through the renovation process. I am going to restuff all the paper caps and can electrolytics and I could also compare part values with what's on the board.
Thanks for any and all help! Icon_biggrin
Robert, in Montreal
Philco model 208 (code 122) - by roddenberry - 03-31-2014, 12:02 PM
RE: Philco model 208 (code 122) - by Radioroslyn - 03-31-2014, 11:04 PM
RE: Philco model 208 (code 122) - by codefox1 - 04-05-2014, 09:54 AM
Philco 91 Tuning Condenser
There are currently 8936 online users. [Complete List]
» 2 Member(s) | 8934 Guest(s)
