41-290 Faceplate Color
I have a reproduction faceplate for my 41-290. It seems way to red (Mahogany) for my radio. Has anybody else had this issue? I'm wondering if I should try a light coat of toner...
I would post a photo, but I no longer have a photobucket account.
41-290 Faceplate Color - by Todd Kaser - 03-31-2014, 12:48 PM
RE: 41-290 Faceplate Color - by Todd Kaser - 03-31-2014, 12:48 PM
RE: 41-290 Faceplate Color - by K7Sparky - 04-01-2014, 05:45 PM
RE: 41-290 Faceplate Color - by Todd Kaser - 04-02-2014, 07:27 AM
RE: 41-290 Faceplate Color - by Todd Kaser - 04-02-2014, 08:17 AM
RE: 41-290 Faceplate Color - by K7Sparky - 04-02-2014, 08:32 AM
RE: 41-290 Faceplate Color - by Todd Kaser - 04-02-2014, 11:33 AM
Philco 91 Tuning Condenser
There are currently 8482 online users. [Complete List]
» 3 Member(s) | 8479 Guest(s)
