  • 1 Vote(s) - 1 Average
Not receiving all stations on AM
#34
I have been useing the original antenna for the radio when playing and testing. I am going to clean the tuner again. I noticed if I tap on the top of the chassis above the tuner cap that it loses the station but I am starting to think that maybe when I do these things the tuner is just moving a very small bit and thats why I lose the station. I am doing more testing... Icon_e_wink
Not receiving all stations on AM - by Warren - 02-25-2014, 02:38 PM
RE: Not recieving all stations on AM - by Warren - 02-25-2014, 09:40 PM
RE: Not receiving all stations on AM - by Warren - 02-26-2014, 12:28 AM
RE: Not receiving all stations on AM - by Jamie - 02-26-2014, 08:59 AM
RE: Not receiving all stations on AM - by Mondial - 02-26-2014, 11:36 AM
RE: Not receiving all stations on AM - by Warren - 02-26-2014, 03:00 PM
RE: Not receiving all stations on AM - by Jamie - 02-26-2014, 11:28 PM
RE: Not receiving all stations on AM - by Warren - 02-27-2014, 12:58 AM
RE: Not receiving all stations on AM - by Mondial - 02-27-2014, 11:07 AM
RE: Not receiving all stations on AM - by Warren - 02-27-2014, 06:21 PM
RE: Not receiving all stations on AM - by exray - 02-27-2014, 06:36 PM
RE: Not receiving all stations on AM - by Warren - 02-27-2014, 11:05 PM
RE: Not receiving all stations on AM - by morzh - 02-27-2014, 11:17 PM
RE: Not receiving all stations on AM - by Warren - 02-28-2014, 12:26 AM
RE: Not receiving all stations on AM - by Mondial - 02-28-2014, 11:38 AM
RE: Not receiving all stations on AM - by morzh - 02-28-2014, 11:53 AM
RE: Not receiving all stations on AM - by Warren - 02-28-2014, 03:03 PM
RE: Not receiving all stations on AM - by morzh - 02-28-2014, 03:43 PM
RE: Not receiving all stations on AM - by Warren - 03-01-2014, 08:55 PM
RE: Not receiving all stations on AM - by Warren - 03-03-2014, 12:26 AM
RE: Not receiving all stations on AM - by morzh - 03-03-2014, 09:41 AM
RE: Not receiving all stations on AM - by Warren - 03-03-2014, 02:50 PM
RE: Not receiving all stations on AM - by morzh - 03-03-2014, 03:35 PM
RE: Not receiving all stations on AM - by Warren - 03-03-2014, 04:15 PM
RE: Not receiving all stations on AM - by morzh - 03-03-2014, 04:41 PM
RE: Not receiving all stations on AM - by Warren - 03-04-2014, 03:18 PM
RE: Not receiving all stations on AM - by Warren - 03-09-2014, 12:31 AM
RE: Not receiving all stations on AM - by Warren - 03-29-2014, 11:53 PM
RE: Not receiving all stations on AM - by Warren - 03-31-2014, 01:39 PM
There are currently 9681 online users. [Complete List]
» 1 Member(s) | 9680 Guest(s)
