Philco knob colors
From what I have seen which is limited to 1936 and 1937 models, 1936 models have black knobs and 1937 models are brown knobs. The limited number of pre 1936 models I have seen have black knobs. The 1938 models I have seen had brown knobs. After 1938 I have no clue.
Bill
It's not what you don't know that hurts you it's what you know that's not so.
Philco knob colors - by Guest - 07-24-2008, 08:28 AM
[No subject] - by BDM - 07-24-2008, 10:16 AM
[No subject] - by wonderwrench - 07-24-2008, 02:42 PM
[No subject] - by BDM - 07-24-2008, 02:45 PM
[No subject] - by Guest - 07-24-2008, 04:18 PM
[No subject] - by wonderwrench - 07-24-2008, 05:05 PM
[No subject] - by BDM - 07-24-2008, 05:07 PM
[No subject] - by Ron Ramirez - 07-24-2008, 05:47 PM
[No subject] - by Guest - 07-25-2008, 08:33 AM
There are currently 11421 online users. [Complete List]
» 2 Member(s) | 11419 Guest(s)
