Zenith 7H822 Dial light?
I have two of these and there is no dial light in either and I can't find one in the schematic. Has anyone ever added one? Is it a good idea to do so?
Here's the schematic
Eric
The Villages, FL
Zenith 7H822 Dial light? - by Eric Adams - 03-31-2014, 05:41 PM
RE: Zenith 7H822 Dial light? - by BrendaAnnD - 03-31-2014, 07:08 PM
RE: Zenith 7H822 Dial light? - by Eric Adams - 03-31-2014, 07:17 PM
RE: Zenith 7H822 Dial light? - by morzh - 03-31-2014, 09:50 PM
RE: Zenith 7H822 Dial light? - by BrendaAnnD - 04-01-2014, 04:15 PM
RE: Zenith 7H822 Dial light? - by codefox1 - 04-04-2014, 03:20 PM
RE: Zenith 7H822 Dial light? - by Eric Adams - 04-04-2014, 05:32 PM
RE: Zenith 7H822 Dial light? - by morzh - 04-04-2014, 06:52 PM
