How many radios?
Generally I don't have more than 1 or 2 in process at a time. That said I have many that are waiting to be repaired or restored but not actually in process. Generally when a radio comes home I will give it a quick check and diagnosis and then it sits til I get to it. Some I need to find a part for or more information. Then like most I go thru periods where other things are more important or I get bored with it all and they sit. I buy what I like at the time and working or not I am happy with them. I have some sitting for 20 years waiting patiently for their turn.
Henry
How many radios? - by OldRestorer - 03-30-2014, 09:10 PM
RE: How many radios? - by morzh - 03-30-2014, 09:15 PM
RE: How many radios? - by skyscraper - 03-30-2014, 09:41 PM
RE: How many radios? - by tom.seeger - 03-30-2014, 09:45 PM
RE: How many radios? - by gregb - 03-30-2014, 10:36 PM
RE: How many radios? - by Phlogiston - 03-30-2014, 10:52 PM
RE: How many radios? - by wireless - 03-30-2014, 10:55 PM
RE: How many radios? - by Warren - 03-30-2014, 11:13 PM
RE: How many radios? - by TA Forbes - 03-30-2014, 11:29 PM
RE: How many radios? - by Raleigh - 03-30-2014, 11:36 PM
RE: How many radios? - by OldRestorer - 03-31-2014, 10:34 AM
RE: How many radios? - by skyscraper - 03-31-2014, 10:45 AM
RE: How many radios? - by Phlogiston - 03-31-2014, 11:02 AM
RE: How many radios? - by wireless - 03-31-2014, 12:08 PM
RE: How many radios? - by TA Forbes - 03-31-2014, 02:32 PM
RE: How many radios? - by Raleigh - 03-31-2014, 03:12 PM
RE: How many radios? - by radiohenry - 03-31-2014, 06:53 PM
RE: How many radios? - by y2kbruce - 03-31-2014, 07:22 PM
RE: How many radios? - by 462ron - 03-31-2014, 09:03 PM
RE: How many radios? - by Section10 - 04-01-2014, 08:43 AM
RE: How many radios? - by PAradiogeek - 04-01-2014, 10:27 PM
RE: How many radios? - by bfrohwein - 04-15-2014, 01:52 PM
RE: How many radios? - by OldRestorer - 04-15-2014, 02:12 PM
RE: How many radios? - by bfrohwein - 04-15-2014, 03:44 PM
RE: How many radios? - by gregb - 04-15-2014, 03:51 PM
RE: How many radios? - by Jamie - 04-15-2014, 07:07 PM
RE: How many radios? - by codefox1 - 04-19-2014, 02:28 PM
RE: How many radios? - by Phlogiston - 04-19-2014, 03:11 PM
RE: How many radios? - by Jamie - 04-19-2014, 03:46 PM
Philco 91 Tuning Condenser
