I guess it pays to be lucky !!
My 118B is just about restored electronically !!
But I needed new cloth for it ! YEAH good luck finding anything close !
But look at what I won on Ebay Tonight !!
Perfect match !! can't wait to try it on !!!
Rock
I guess it pays to be lucky !! - by rocklandman - 03-31-2014, 09:57 PM
RE: I guess it pays to be lucky !! - by morzh - 03-31-2014, 10:00 PM
RE: I guess it pays to be lucky !! - by codefox1 - 04-04-2014, 03:38 PM
RE: I guess it pays to be lucky !! - by TA Forbes - 04-04-2014, 08:19 PM
Philco 91 Tuning Condenser
