Philco knob colors
Bill Fulling Wrote:Ah So! I think I'm getting a consensus of opinion here,and it looks like "36 and earlier knobs are black and '37 and later knobs are brown.
Am i reading this correctly?
73 de bill
That's the way I see it. We need to hear from Ron or chuck to know for sure.
Bill
It's not what you don't know that hurts you it's what you know that's not so.
Philco knob colors - by Guest - 07-24-2008, 08:28 AM
[No subject] - by BDM - 07-24-2008, 10:16 AM
[No subject] - by wonderwrench - 07-24-2008, 02:42 PM
[No subject] - by BDM - 07-24-2008, 02:45 PM
[No subject] - by Guest - 07-24-2008, 04:18 PM
[No subject] - by wonderwrench - 07-24-2008, 05:05 PM
[No subject] - by BDM - 07-24-2008, 05:07 PM
[No subject] - by Ron Ramirez - 07-24-2008, 05:47 PM
[No subject] - by Guest - 07-25-2008, 08:33 AM
There are currently 10839 online users. [Complete List]
» 2 Member(s) | 10837 Guest(s)
