41-290 Faceplate Color
Have you looked at the 41 pictures http://www.philcoradio.com/gallery/1941a.htm
I just got what looks the same as yours for my 41-280 and my original is warped & cracked but would guess there was a bit of differences in the originals also.
The pictures of the 41s look like there was a fair difference, but may be just the photo taking.
What did you use to clean up your brass strip? Looks good. I don't want to mess mine up cleaning.
I used GoJo on the station calls for the push buttons and the 3 little clear covers I have.
Have you found any links on what is being used to gin up new push button call letters?
41-290 Faceplate Color - by Todd Kaser - 03-31-2014, 12:48 PM
RE: 41-290 Faceplate Color - by Todd Kaser - 03-31-2014, 12:48 PM
RE: 41-290 Faceplate Color - by K7Sparky - 04-01-2014, 05:45 PM
RE: 41-290 Faceplate Color - by Todd Kaser - 04-02-2014, 07:27 AM
RE: 41-290 Faceplate Color - by Todd Kaser - 04-02-2014, 08:17 AM
RE: 41-290 Faceplate Color - by K7Sparky - 04-02-2014, 08:32 AM
RE: 41-290 Faceplate Color - by Todd Kaser - 04-02-2014, 11:33 AM
Philco 91 Tuning Condenser
There are currently 6964 online users. [Complete List]
» 2 Member(s) | 6962 Guest(s)
