Refinishing the chassis compartment
I did kind of what was mentioned above on my 41-280
Vac, wipe and at first a small sample area of GoJo. In the end a good slop of GoJo and lots of wiping out with paper towels. It is a bit rough so tore up the towels some
It did not hurt the decals and other tags glued inside. The GoJo feeds the wood and looks a lot better.
I unscrewed the speaker mounting frame and pulled out the grill backing so I would not get the cloth gooped up and could get to the back of the grill bars. I also did the GoJo treatment to the rear exposed face and edges of the speaker mounting frame.
My first cabinet redo so not proceeding too fast. Reading a lot before I venture forth.
Plan on looking over a bunch of the redone ones at Dayton this year. Had not paid much attention to them before.
RE: Refinishing the chassis compartment - by TimC - 03-25-2014, 08:24 PM
RE: Refinishing the chassis compartment - by K7Sparky - 04-01-2014, 06:15 PM
Philco 91 Tuning Condenser
There are currently 9386 online users. [Complete List]
» 2 Member(s) | 9384 Guest(s)
