Philco 39-30 Code 121 Push Buttons - Problem Found!
I am presently working on a Philco 39-30 Code 121. The broadcast band and short wave band are working nicely. The push buttons do not work. I have taken an oscilloscope and looked at Pin 5 of the 6A8 and I get signals on all eight pushbuttons. I have not changed the 370 uuf capacitors yet.
Suggestions would be greatly appreciated.
Thank you,
nv3g
Oscar
Philco 39-30 Code 121 Push Buttons - Problem Found! - by NV3G - 04-03-2014, 11:59 AM
RE: Philco 39-30 Code 121 Push Buttons - by NV3G - 04-03-2014, 05:28 PM
