Philco 39-30 Code 121 Push Buttons - Problem Found!
John
Thank you for the excellent reply. I have checked most of your suggestions but not all of them. I will go step by step and check everything you have suggested.
Thank you and best wishes,
Oscar Ramsey
RE: Philco 39-30 Code 121 Push Buttons - by NV3G - 04-03-2014, 05:28 PM
There are currently 4365 online users. [Complete List]
» 1 Member(s) | 4364 Guest(s)
