Philco 86 lowboy, what speaker?
I just ended up with a decent Philco 86 Lowboy cabinet today. Only thing missing is the back and (of course) the speaker grill insert. I might have already located a chassis, but what type speaker did this use and what other Philco speakers might work?
Philco 86 lowboy, what speaker? - by Jayce - 04-03-2014, 06:28 PM
RE: Philco 86 lowboy, what speaker? - by TimC - 04-03-2014, 08:18 PM
RE: Philco 86 lowboy, what speaker? - by Jayce - 04-03-2014, 08:33 PM
There are currently 6972 online users. [Complete List]
» 1 Member(s) | 6971 Guest(s)
